Old 02-03-2009, 11:55 AM
priobe's Avatar
priobe priobe is offline
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
Default mounting of sidepipe
I was thinking of changing the way my sidepipes are mounted. Currently thay are held in place with a rubber muffler strap and I am noticing that the arm off of the sidepipe is weaking from the welded area.
I was thinking of using a heavy duty spring so that it would have more of a give away when the motor torques over.
Can you show the mounting of the side pipe to your chassis
Thanks
Last edited by priobe; 02-04-2009 at 06:33 AM.. Reason: this is what happens when you work too hard
