Old 02-05-2009, 04:37 AM
PANAVIA's Avatar
PANAVIA PANAVIA is offline
With all electrical items off (key off all switches off) you can measure the harness resistance between + and - battery cables ( both disconnected from battery ) with a multi-meter set to OHMS/Resistance.
then you can perform the tests that Blas mentioned and see which fuses and other items impact resistance and subsequently drain the cells'
Steve
