Old 02-07-2009, 01:35 PM
jimhurtt jimhurtt is offline
Cobra Make, Engine: 91, 65 CR 427 289 or 302
Default Gee thanks DV. They said you were "the man".
Thanks for the great info. Gives me some feel for what I have. I've been told running a car fax on these Vins is fruitless. Can you buy the rod for the trunk support or is it something you have to fashion yourself? I just jacked the car up and crawled underneath. Very well made and fortunately very clean. Only problems I have discovered so far is the three piece lower radiator hose leaks at clamps. I will remove the whole thing and see if I can luck out and find a one piece with the proper curves. Also definitely have an oil leak where the oil dipstick tube goes into block on front of engine. It is broken loose there. I am hoping that tube is replaceable and not welded to the block or an integral part of it. Looks like a previous owner tried to epoxy it. Also appears trunk latch cable is broken as lever by seat does not move latch. I can't wait for a sunny, dry and warm day here in KY to get it on the road.
Jim
