Old 02-08-2009, 04:48 AM
Default A little more info would help.
coin101op Peter What are you looking for from the car? roadracer? cruiser? 1/4 mile? caddie ride? You would have a different setup for each one of these driving styles. Which QA1 shocks are you using? What is the spring rate of the front springs and weight of the car. What size tires are you running? You can run a higher spring number rate with a lower profile tire. You will get a harder ride but handling will be better. Does the car have front and rear sway bars? All this needs to be added into what you are looking for. You can see why I am asking for a little more info. You have single spring and shock in the rearend for each side. A 350-400 would be the choice without knowing anything else. This would include 2 people in the car with a 375 total wieght. Again looking for a little more info. Rick L.
