Thread: Build update
Old 02-09-2009, 03:23 AM
AC-460's Avatar
AC-460 AC-460 is offline
Cobra Make, Engine: BBF 545 Stroker Alloy Heads Roller Cam Aluminium Flywheel Twin plate Clutch TKO600 9inch Independent Rear 335x17 Rear 315x17 Front 1140kg
I cut out all the fibreglass and went stainless on the guards... I covered the footboxes with stainless and left a 5mm air gap between the stainless and the fibreglass as a heat shield no heat insulation inside and its as cool as a cucumber inside. Go stainless it's easy to clean
http://www.clubcobra.com/photopost/s...3&ppuser=33566
