Old 02-10-2009, 08:30 PM
DAVID GAGNARD's Avatar
Originally Posted by 767Jockey View Post
Geez, would I love it to be that simple. How would that cause the oil burning? Would that malfunction in a way that it sucked up oil from the crankcase and burned it? That would sure be a quick easy fix.
Yep, could be that, easy to check.....if it is not that, pull all the plugs and run a compression check, then one at a time, add a couple of squirts of engine oil into each cylinder and run compression check again..... if the compression goes up, it's the rings, if the compression is low and stays low, it's the valves...
David
DAVID GAGNARD
