Old 02-10-2009, 07:49 PM
Bill Wallace's Avatar
Bill Wallace Bill Wallace is offline
Cobra Make, Engine: Kirkham 557
Default 482 specs
You had asked about cam specs: I got the folder out and here are the specs from Keith Craft...
Comp Camps Hydraulic Roller
242-248 duration with .645-.635 lift at 110 degrees
Crane hydraulic roller lifters were used with Erson rocker arms
Scat rods with an eagle cast crankshaft
Diamond pistons
Melling oil pump
Ford racing timing set
Edelbrock heads
PEP dual valve springs
Smith Bros. pushrods
Edelbrock performer RPM manifold
Quickfuel 780 cfm carburetor
MSD 6AL bos with a high vibration coil
McLeod aluminum flywheel with a Quicktime bellhousing
604 hp @5600 rpm/628 ft. lbs @ 4400 rpm
