  #133 (permalink)
Old 02-11-2009, 02:56 PM
fkemmerer's Avatar
fkemmerer fkemmerer is offline
Cobra Make, Engine: ERA, FE BBF
Fred- I have yet to read through all the posts here and your build site but, the car is awesome, inside & out. Great job !
With the 482's HP/TQ and EFI, have you had enough time to see what the fuel mileage is ? It usually descent matter but, I'm curious anyway.
Also, is your website down ? I tried and it did not work.
Thanks,
Kevin,
Not sure why you had trouble accessing my website - I may have posted an incorrect URL. In any case, try this link - it should work:
http://www.anitafred.net/Cobra.htm
The combination of the driveshaft sensor and the FAST computer can output instaneous MPG readings. I don't have the driveshaft sensor calibrated accurately enough to be sure but I've see cruise numbers in the 15-17 MPG range with my car in Overdrive (I'm running 3.54 gears with a .64 overdrive which is pretty tall).
- Fred
