Old 02-12-2009, 09:25 AM
Bobcat Bobcat is offline
To add to what has been said .... a friend of mine who was involved with NASCAR back in the late 60`s said the problem with the C/O was in the upper rpm range . At sustained high rpm , the bearings would fail ... which from the other posts makes sense . He claimed on the shorter tracks where they didn`t stay at max rpm as long , the C/O worked fine . When the S/O came along , he said it allowed them to run higher rpm for longer periods without bearing failures .
