Old 02-13-2009, 10:43 AM
Rpollard Rpollard is offline
Cobra Make, Engine: Lonestar / 408W Stroker
Default 428 / 461 cubic inch for sale
1966 428 PI block 2 bolt
461 CI FE, Dyno Tested and Tuned
Will come off Dyno Friday 2/13/09
4.160 bore, 4.250 stroke, 10.1 compression
RPM H-Beam Rods
Scat Cast Steel Crankshaft
JE Pistons
Plasma Moly Rings
Heat Treated Bearings
Balance Assembly
Hydraulic Roller Camshaft
Double Roller Timing Set
Needs Stock Front Caver
Stock Damper
Needs Water Pump
Edelbrock Aluminum Sage II heads
Earson Roller Rockers
Comp Cams Push Rods
Edelbrock Dual Plane Jr Victor Intake
Crane Lifters
ARP Fasteners
MSD Billet Distributor
MSD Blaster High Vibration Coil
800 Holley Carb
Ford Racing Torque Starter
Alum Bell-housing
Billet Steel Zero Balance Flywheel
Remote Oil Filter and Mounting Brackets
All The Right Stuff!
Located Etiwanda, CA 91739
roypollard@verizon.net
$8,500.00
HMIHNTR
Lone Star LSC427, Speed-o-Motive 408 Stroker
2005 Ford SD 6.0 Harley Davidson /Super Chip 425 HP
1975 24' Campbell V-Drive / 1963 427 Ford
2000 Prowler 32' 5th wheel
And the Harley pulls them both to Lake Havasu
