  #24 (permalink)
Old 02-14-2009, 04:50 PM
patrickt patrickt is offline
Your engine is new and possibly a little tight. Give it some time to break in. If you're still having the same problem after a couple of hundred miles then it could be the connections to the starter motor, the starter motor itself, or just a timing adjustment. New engines need to break in a bit even if they were broken in on the dyno.
