Old 02-15-2009, 12:20 PM
Default I never question you skills for welding
undy Dave I NEVER question your mig or tig welding ability. You should be a MASTER BLACKSMITH. You line of work has you mating anything to any thing and welding anything from Aluminum to cast iron to now plastic. Home depot sells carriage flat bolts that the head is only 1/8". This way you don't have to worry about the head hanging the mount from laying flat. You could also with a little more work drill a second hole in the frame mount and use a longer bolt on each side to limit the same thing. Just spit farting here. Rick L. How's the spring looking for the beach????? Rick
