Old 02-16-2009, 09:55 AM
Great Asp's Avatar
Great Asp Great Asp is offline
Cobra Make, Engine: SPO 2715
Urban areas? Forget horsepower for the time being -- horsepower is only a function of your torque value at a given RPM (the higher the RPM the higher the horsepower, even with the same torque). In an urban area you're not going to be winding it out much, but you do want that blast in the back from a strong torque motor. 450 ft/lbs will do you nicely and a good flat torque curve that comes in early and stays flat will make you happier in the city.
this is correct, especially if this is your first Cobra.
However, if you build to 500 hp or more, think about a block of wood under the "WOW" pedal until you get used to the car.
400 - 500hp is more than enough, you should never get bored with it, unless you have owned 600 - 700 hp cars weighing 3500 lbs or more before.
E
