Old 02-18-2009, 10:53 AM
priobe's Avatar
priobe priobe is offline
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
Default ???? Method you use to adjust float 10 degree..
What method do you guys use to adjust the float on the 48 IDA with the 10 degree cut manifold.
I purchased the sight glass tool but the values will not be the same as if it was mounted straight.
I tried using the method of lifting the float 5 -6 mm and adjusting the tang to 24.2 but it does not register on the sight glass.
Just looking to see what others are using.
