Old 02-19-2009, 07:02 PM
Got the Bug's Avatar
Got the Bug Got the Bug is offline
Originally Posted by Blas View Post
Perhaps you could post the supplier info and part numbers?
Blas760
For sure. This is courtesy of Scott (Scooter) who provided me with the part numbers.
The supplier is BAT (British American Transfer) In Florida).
http://www.batinc.net/main.htm
- 1 x Fitting ABS390F 90 deg 1/8" BSP x -3 hose end ( for Smith Gauge Flat Seal - British Standard Pipe Fitting)
- 6' Hose FC3-3T TFE -3AN TEFLON
- 1 x Fitting 816-3-2 Union -3AN x 1/8" NPT
- 1 x Fitting FS-3 -3AN Straight Hose End (TE)
The assembled line was $64.00 which included $7.00 to install the hose ends. You can assemble it yourself (would make it easier to fish through the firewall), but I thought I'd let a pro do it. The full 6' is perfect for the SPF.
I ran some of the AN line under the dash through a piece of wire loom to prevent rubbing on the wiring harness.
Doug
