Old 02-19-2009, 08:57 PM
Three Peaks Three Peaks is offline
Gforce makes a T5 with the .72 fifth and .80 is also available in the T5 from Astro and a couple others I can't recall right now.
You might check what first gear you have in your particular T5. The T5Z and some of the aftermarket T5's come with a 2.95 first gear. However, the earlier T5's came with a 3:35 first gear which would work better for your purposes.
Having a T5 built with the right combination of gear ratios would probably be your best bet, all things being considered. Check with Gordon Levy or Modern Driveline and you should be able to find what you need.
Bob
