Old 02-22-2009, 06:54 AM
mikeforte mikeforte is offline
Hi Bob,
If you have the 3.46 rear gear you'll be going about 67 MPH @ 3000 RPM. If you have a TKO-600 with a .82 5th it will reduce your RPM to 2460 RPM. In 4th gear your 2000-3000 RPM is about 44-67 MPH. In 5th your 2000-3000 RPM will be 54-81 MPH. These speeds are all figured with a nominal 26 inch rear tire.
Before you purchase a transmission you need to think how and where you plan to drive your car. Back roads, highway cruiser, fast lane blasts and at what speed will determine which model and gear ratio will fill your needs best.
Call me with any questions.
Mike Forte
Forte's Parts Connection
40 Pearl St
Framingham, Ma. 01702
fortesparts.com
508 875 0016
In 1993 Mike made the first conversion of a Ford Tremec to GM 5-speed. It bolts to stock bellhousings w/out an adapter. The FE Tremec, the Mustang adjustable quadrant are originals from Mike.
One of 12 Tremec Elite Distributors worldwide for: T-5, T-56 Magnum & TKO-500 & TKO-600 ,Midshifter, Frt shifter, offset Vette shifter.
Est: 1981 selling performance parts to build your dream car...
