Old 02-23-2009, 11:29 PM
Monster's Avatar
Monster Monster is offline
Cobra Make, Engine: Arntz/Bennett, FE with lots of shinny parts that make it go fast
I've been running Delo 400 (same oil I run in my F350 PSD) because of the added zinc ( zinc dithiophosphate or ZDDP ) in current FE build since break-in which now has 3Kmiles.
From ad for ZDDP Plus Oil Additive:
After 70+ years, the EPA mandated that all domestic oil producers remove ZDDP (Zinc Dialkyl Dithio Phosphate) from all conventional and synthetic motor oil. If your engine was designed before 1989 the non-roller lifters require ZDDP to avoid premature deterioration. ZDDP also alters bearing and journal surface characteristics to prevent metal to metal contact. Under extreme conditions like a high performance motor, ZDDP reduces the tendency of parts to scuff or gall under heavy loads.
I haven't used this additive but I did go with Delo because of the added ZDDP and the protection it provides. I have since found that "newer" Delo 400 LE (Low Emissions) does not provide ZDDP at the same levels as the older version of Delo. I am going to do further investigation on ZDDP additives.
Thanks for the post.
Mike
