Old 02-25-2009, 11:24 AM
priobe's Avatar
priobe priobe is offline
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
I dont recall my pump jets ever leaking. I have tried shutting down my pump to lower the level a block before shutdown. It still leaks
The only thing in my situation that changed was new pump jets( which I replaced back to the old) and float level (which I lowered before shutdown.
The carb bodies themself are cool to the touch.
Zimmy,
Has your system always leaked?
Eljaro,
I dont recall other complaining about the leaking from the pump jets.
Rick,
I am not saying you are not correct but it seems something changed to cause the pump jets to start leaking. Or I never noticed it.
One thing, if you block the by pass all hell breaks loose through the pump jets.
Maybe its the fuel?
Just when I think I am moving forwad with these carbs I go 1 step back.
