Old 02-25-2009, 06:08 PM
roadrod2000's Avatar
roadrod2000 roadrod2000 is offline
Cobra Make, Engine: Unique 289 FIA HiPo 289 with Shelby dual quad intake
Default Jag rear end front to back alignment
I have been working on my Unique 289 FIA and discovered that the rear axle (a Jag unit) was tilted slightly to the right. I have corrected that alignment issue (not easy because it meant relocating the mounting plate that is welded to the frame above the axle) and now I am trying to find information on the alignment of the axle front to back.
I am trying to determine if the rear axle (which hangs from a top mount) needs to be tilted forward or backward from a "level to ride Height" position and thus changing the direction of travel of the rear suspension from straight up and down to slightly forward or backward. Thanks in advance for the help
Rod
