  #27 (permalink)
Old 02-26-2009, 06:27 AM
priobe's Avatar
priobe priobe is offline
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
Carmine,
Well scratch that idea. Anyway, I think I will try to slip a piece of heat barrier material below the carb body between the intake just to see the results.
If that is the case then it will have to be adjustment of the fuel level. If what you are saying is correct, then all setup should recieve the pump jet problem. Is this limited to only the BBor do the SB have the same problem.
Rick do you have the same problem.
What do you think about added fuel in the bowl to raise the boiling point, ie increasing the volume of fuel?
