Old 02-26-2009, 08:18 PM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
Well, I guess I would start by inspecting the main ground cables from the battery to the chassis and then the one from the engine (Usually off a starter bolt) to the chassis. Check the battery cable ends too with the clips on them. Have you load tested the battry? What gauge wire are you running for the main grounds and main power? Next time it won't crank, pull out a jumper cable and connect on side to the negative battery post and the other to a good chassis ground...
SPFWiringDiagrams@Comcast.net
