Old 02-28-2009, 09:02 AM
Stentor's Avatar
Stentor Stentor is offline
Cobra Make, Engine: CSX 4000; Shelby aluminum FE with 58mm IDAs
The axles may be ok with such a light car and I will not be using slicks. As we all know, a hard launch with sticky tires is very hard on all the drive train.
From the start, I've trusted Keith and always will.
Do you have a aluminum flywheel, if so, how do you like it ?
I don't quite understand some problems with starting from a traffic light with a alum. flywheel ?
The GY Billboards that you are getting are going to hook up much better than your current tires.
Yes, Keith knows his stuff--follow his guidance and you should be in good shape.
Incidentally, I have a McLeod Street Twin clutch and aluminum flywheel and have been very pleased.
