Old 02-28-2009, 09:49 AM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
Also a couple other things I should mention---don't call them J pipes in conversations with them as that is a tube with a 180 bend and one leg longer than the other---
You want 90 degree bends and you can get them to custom bend them with the lengths you need.
And you will want to get 4 that are 3 inch centerline radius and 4 that are 5 inch center line radius so they will nest together at the turnout to the collector
