02-28-2009, 01:46 PM
KY
Also, if you post your cam and intake specs, I'll be able to tell you where your hp/tq peaks will be. That will help in deciding on the overdrive ratio. Usually solid rollers give a hint that you're gonna be spinning the engine pretty high, but large a displacement will tame a large duration.
