Old 03-02-2009, 09:32 AM
madmaxx madmaxx is offline
Some quick fixes for other items. 1) speedometer CABLE leak, not cable not interface between transmission and cable, use some rtv on the crimp where the flexible cable goes into the metal part by the transmission, mine would drip a drop every couple days. 2) lubricate your rear anti sway bar bushings, if not it will sound like the tire is rubbing the fender when you go over dips. 3) take off the remote reservoir for clutch and disassemble top from bottom, put SEAL ALL on bottom and slide top over, tighten clamp. It will leak clutch/brake fluid if you do not.
