Thread: Stuck Valve??
Old 03-04-2009, 03:37 PM
Mac VABCH's Avatar
Mac VABCH Mac VABCH is offline
Cobra Make, Engine: BDR #250
Default Sticking Valve
I had a bent valve and at idle it just stumbled a bit but not bad. At wide open throttle motor was strong and there was not and hesitation to rev. A easy check to see if all cylinders are firing is to spray water from a spray bottle on to each header tube while the engine is running. If it sizzle and evaporates the water right away its firing...
