Thread: Stroking a 351w
Old 03-05-2009, 11:04 AM
bmcnicho bmcnicho is offline
Cobra Make, Engine: Classic Roadsters, 351W
Default CHP 427 stroker rotating assy
CHP sells a 6.125"rod length/22cc and a 6.200"/28.9cc rotating assembly. I was leaning toward the latter since it is a slightly higher rod ratio & lower compression ratio. The lower compression ratio should make it tolerant of pump gas. Do you have inputs between the two assemblies?
