Old 03-08-2009, 04:33 PM
Default Send them back and get custom ones from ASP
FuzzyDiceRide Sent them back and get a custom set made for the car from ASP IMO they are better than March and line up perfect. You just need to tell them diameter of pulley, back space, number of grooves, Vee belt or surp. How many bolt hole for mounting surface. You will have them in 48 hours. Make sure you have the correct backspacing and bolt holes correct. Tell them weather you want under drive or overdrive on the water pump and ALT. Rick L. They are the same price as March if not less. Show quality.
