Old 03-08-2009, 08:09 PM
Inglese Inglese is offline
Default Inglese™ Electronic Fuel Injection Induction Systems
New Inglese™ EFI systems have all the flash of classic Weber induction but provide higher state of tune and engine performance versatility
The new Inglese™ EFI Induction Systems may look like classic Weber induction, but these highly advanced systems deliver performance capable of supporting up to 1000 hp engines. Inglese™ uses FAST™ advanced XFI™ electronics, Dual-Sync Distributors and Precision-Flow™ Fuel Injectors (GM LS7 type) integrated into precision cast aluminum 50mm IDA throttle bodies. Best of all, with your Inglese™ EFI system camshaft choice is greatly increased, allowing for precise targeting of the horsepower and torque to be generated – something not possible with standard Weber carbureted engines. Inglese™ EFI Induction Systems can also be purchased without the FAST™ XFI™ engine controls and distributors for use with existing EFI engine controllers.
The Inglese™ EFI systems feature an aircraft-quality hex aluminum linkage designed to provide trouble free actuation. The manifold uses custom-engineered, low-profile fuel feed rails that sit below the stacks and between the throttle bodies. This amazing system is engineered to deliver trouble-free service under normal heat environments and avoid the common binding found with many inferior systems.
To properly design the Inglese™ EFI system that’s right for your engine, follow four simple steps. First, choose the “base kit” determined by the type of engine you have (base kit will include the intake manifold, throttle body assembly and complete FAST™ XFI™ kit and Dual-Sync Distributor). Next, choose the correct injector size for your system based on the targeted horsepower to be achieved. Third, select the size and finish of the velocity stacks and finally, the proper fuel pump kit. An Inglese™ expert can provide invaluable guidance in the selection of these components. For help putting together your custom Inglese™ EFI Induction System, call us at 1-866-450-8089, or visit us online at www.inglese.com.
Quick Summary
Product: Inglese™ Electronic Fuel Injection Induction Systems
Part Number: Application Specific
Features & Benefits:
• Complete EFI kits feature FAST™ XFI electronics and Dual-Sync Distributors to support up to 1000 hp engines
• User can choose camshaft from wider selection than Weber carbs allow
• Custom engineered fuel rails sit below the stacks and between throttle bodies
• Kits are optionally available without FAST™ XFI™ engine controls for use with other EFI engine controllers
• Injectors, stacks and fuel pumps sold separately
Visit The Inglese Website
