Old 03-09-2009, 10:36 AM
markha markha is offline
OK.. Got it. Thank you for all your help.
I drilled all the carbs for the third progression hole. Was not nearly as difficult as I thought it would be. Stuck each one in a good drill press vise and drilled a 1mm hole so that they are all in a triangle pattern.
Do you know how to drill jets? Are they just fractions of a cm or something? So is a 200 air corrector .200 of a cm? But then would a 60 idle jet be .06?
