Old 11-06-2001, 08:53 PM
jdean's Avatar
jdean jdean is offline
Default Similar plan - BBF with C6
Hi Tom,
It is good to get some validation of similar set-ups.
For the car I am building, I also have a 460, relatively mild ( Torker II, vacuum secondaries, medium cam, tweaked heads, 9.4 CR) Torque is a bit north of 500 lbs. I do have the B&M shift kit in the C6 I am planning to use, also with a SNS converter. Rear end ratio is 3.08. Will be for 98% road use.
Jack 21 - when I read your advice to Tom, I am thinking I might have goofed already on one decision.........When I put the shift kit in the C6, I used the "firmer" shift option (you know, where you drill the one hole in the plate bigger and use the extra ball bearing) - Do you think this might leave it shifting too harsh for my set-up?
