Old 03-10-2009, 08:05 PM
767Jockey's Avatar
767Jockey 767Jockey is offline
Originally Posted by strictlypersonl View Post
If you're interested, ERA has the handle, cable, bracket and compensator for the XJ rear. About $300 total. I'm not sure the mounting bracket will fit your chassis though. If I knew the center-to-center distance of the main rails I would have a better idea.
Bob,
My rear calipers are Series II XKE Girlings - will your setup work? My old arrangement had the lever assembly mounted to the side of the fiiberglass tunnel, which actuated a cable that had the sheath anchored to the passenger side E brake caliper lever, and the core cable anchored to the driver side E brake caliper lever. Pulling the handle together squeezed the two together (at least in theory, it actually didn't work very well at all) applying the E brake. How does this compensator mechanism work? I appreciate the offer to assist. Thanks.
