Old 03-12-2009, 08:32 AM
FWB's Avatar
FWB FWB is offline
Originally Posted by fastedy View Post
Orskov. what is the VIN # that your trying to verify? This a 12 digit # is either on the
right frame rail by the upper suspension arm OR on the front crossmember directly
in front of the engine.
As for the order of the manufacture of the cars it is documented, you just have to
know who to ask. As for the chassis # exceeding 117, thats because the numbering
system starts at 100. So the car that your looking at (if it's # 46) would have #
146 in it's VIN #.
Hope that helps Fastedy
the vins starting at 100 and they being sequential does not make sense.
for example my stallion is vin #129 according to your vin explanation it is the 29th car.............that would mean kellison only built 29 cars from 1976 to 1979. kellison had 3 or 4 other cobra builders as vendors for his chassis and bodies, vins were issued to cars without their sequence in mind. also the vin being stamped in the places you describe was in effect the builders responsibility. some cars do not have a vin plate or it stamped on the car anywere. your info comes from where? if this is documented info please share i am sure the rest of us at the kellison registry would welcome the info.
