Old 03-13-2009, 11:20 PM
Maurice Butler's Avatar
Maurice Butler Maurice Butler is offline
Cobra Make, Engine: Scratch build, with help
Liquid nitrogen on the pin works magic - you need good full leather gloves and it burns real deep fast - doctors use it to burn out warts.
when you go to buy it take a large thermos - and don't screw the cap on too tight as the gas that boils off need to go some where.
Great also for fitting interferrence bushes - drop the bush in the liquid nitrogen - then slip into place.
Be real careful with it! the gloves are there to give you enough time to wash it off with lots of water before it burn through the gloves. Also safety glasses, apron and cover boots essential. It flows like water so make sure if you pour on to the pin it has some where to flow. Pratice with water first but make sure its dry before using the liquid nitrogen.
Maurice
researching for scratch build
