Old 03-15-2009, 08:43 AM
Double Venom's Avatar
Double Venom Double Venom is offline
OK,
The last stage of the cold weather work, tranny cooler lines, extending all the wires to the trunk for the regular harness-two computers-mounting and shortening the wires for the receivers(electronic controls) is now done and everything is tucked away.
Standing back inspecting my work I found a lose black wire mixed in with all the other wires. At this point there should be NO loose wires! I picked through the open harness only to find my loose black wire was a vaccum tube for the heater! Geeeesh I had the heater done months ago! Everything done except hooking this main vaccum to the engine!
I for one hate to see anything clutterd anywhere on the car-a OEM -vaccum 'T' off the booster never has looked good to me and I only wanted one vaccum line other than the booster. (Some day I will take the time and figure out a way to camouflage it!)
My answer: Instead of using a large ugly vaccum T I pulled out an OEM plug from the manifold found a brass insert that was also threaded inside and a very small compression fitting. (normally used for an oil line gauge). I then installed a nylon plastic tube in the compression fitting and screwed it into the brass fitting after I retapped it internally to accept the pipe threads from the compression fitting. When that phase was done I sanded the little piece, primered it with self etching primer then painted the entire asembly with semi gloss silver.
Looking at the pictures you might ask how I got the nylon tube to bend 90's and then straight without any kinks?............A heat gun-warmed the tube to 'flexible' then worked it the way I wanted it. Ok, it looked good but it was just another line coming to/from the motor. I made use of the "choke Cable". Using very small wire ties that I also painted silver I then attached the vaccum line to the bottom of the choke cable. I then drilled a small hole in the firewall, ran the tubing over to the heater solenoid and plugged it in!
DONE.
