Thread: Four post lifts
Old 03-16-2009, 06:44 AM
madmaxx madmaxx is offline
Exactly Bobcatt,
Once again the question is, do you want to build the 4 post lift yourself?, the cheap chinese do not come with lock valve where the higher ends ones do. Soooo if you are mechanically inclided to find a lock valve and know where to install and inspect your hydraulic lines, then buying a cheap chinese made may be fine, if not buy the better lifts. I found the cable dragging across my hydraulic line to the point where the outer coating was worn away and the braiding was shown.
