Old 03-16-2009, 11:04 PM
elmariachi elmariachi is offline
Originally Posted by mikeforte View Post
Hi,
You could grind the input to correct the interference. Do you have anaerobic sealer?
Yes I have the sealer from when we swapped shafts a month ago. I have pulled the short shaft this evening and am just going to run it over to the machinist and have 3/16ths milled off and be done with it. If he weren't 10 minutes away and dying to see me finish this, I would have already just ground it down.
I am still curious where the tolerances are off, but I know the pilot bushing is correctly seated and the bellhousing is firmly bolted on, so either Tremec or Lakewood got it wrong somewhere. Thanks for the input Mike.
