Old 03-17-2009, 12:59 PM
767Jockey's Avatar
767Jockey 767Jockey is offline
Originally Posted by shelby racer View Post
I just talked to a local shop that works on the first road going 4000 series (built in Las Vegas - unlike the 4700 series that was built else where). The original 4000 series is like a normal car. You remove the caliper and the rotor slips off the hub. My hub has the bolt on the back side and the rotor is pressed on to the hub. I have no idea why it was designed this way, but in my uneducated mind it seems like a step back ward. I will attempt to attatch an image and we can go from there. you can just see the bolts behind the rotor and you have to remove the entire assembly and press it off the up right.
The rotor and hub assembly is press fit onto the spindle? Again, I am no CSX guru by any means, but I have never heard of such an arrangement. It seems like a solution to a problem that no one has identified yet. Obviously, I am missing something here...is this car still under warranty? Tell them to recommend a shop by you and let them foot the bill if it's under warranty, why mess with it?
