Old 11-08-2001, 08:13 AM
Ken Oikawa's Avatar
Ken Oikawa Ken Oikawa is offline
Gary
Nice looking setup!! What size injectors are you using and are you planning on using air filter of some sort?
Don't like the open trumpet, could inject some foreign objects and damage an expensive motor.
I'm doing the same thing, except mine is a Hilborn FI converted to EFI. I'm planning on using a 40-50 #/hr injectors with Aeromotive fuel pump, Bosch fuel regulator, MAP sensor, MSD crank trigger, wide band O2 sensor and a Motec ECU. Still searching for the injectors at this time and once it is purchased, my EFI system will be on my engine this winter.
Regards, Ken
