Thread: Bemini top
Old 03-19-2009, 12:28 PM
Steve Gallegos Steve Gallegos is offline
Default Bemini Top
The cost for the top material and labor was $260.00. I had to buy the 2 front bars that go over the windshirld, just like the ones used with the regular soft tops, they were about $180.00 from ERA. You can also get them from SPF, but they cost more. The frame for the top, I use my frame from the soft top that I have. The sides and back are open. There are 2 staps one on each side that connects to the snaps on the car for the regular soft top. If you want side windows and have the holes drilled in the top of your doors for the regular windows, you can have window made of plexy glass and use a 1" aluminum angle arm, I bought it at Home depot, and attach one side to the plexy glass with about 6 small bolts. then drill the other side so you can put a 3/8 bolt through it to go into the door holes. The window cost me about $100.00 to make. I'll try to get pics up within a week or so. Steve
