Old 03-20-2009, 11:03 AM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
You are not really checking the operation of the solenoid, you are checking the output of the alternator without using the Smiths dash gauge...so now you would know if your charging system is working properly...
When you give the car a boost, what are you connecting to with the jumper cables...The batteries?
Aren't you actually running a new ground and power from the booster battery to your car?
When you use the jumper cable as I mentioned, you adding a new ground to your battery. If it starts, you have a gound problem on your car's battery...
SPFWiringDiagrams@Comcast.net
