Old 03-20-2009, 03:37 PM
Three Peaks Three Peaks is offline
Agree with the above, but after tacking everything together on the outside tubes at the flange, weld the pipes on the inside of the flanges and grind the weld down when you're done. Much cleaner job when you are done and you can grind off the outside tack welds with a die grinder and really clean it up.
Bob
