Old 03-20-2009, 08:43 PM
SoTxButler's Avatar
SoTxButler SoTxButler is offline
Cobra Make, Engine: Butler...488" hi-rise, dry-sump FE s/o w/stacks
I guess I got LUCKY.
Speaking first hand, the Dove aluminum 427 block, the DOVE aluminum high riser heads, the DOVE "tall and terrible" intake manifold, the DOVE timing cover, the DOVE water pump, and the DOVE dry sump pan and pump have all performed flawlessly now since 1993. No leaky castings, no extra machining, no nothing. Oh, I forgot, the DOVE shaft mounted rockers too.
All this went together with a Moldex billet crank, carrillo rods, arias pistons, Comp Cam, etc., and it all worked properly.
Now that I know DOVE makes nothing but JUNK....guess I just got LUCKY!!!!!!
Russ
