Old 03-22-2009, 07:35 AM
madmaxx madmaxx is offline
I also see you just got the engine and trans installed.
1) Grease all ball joints / u joints.
2) Regardless of the paint on the bolts tighten each and every bolt and again at 500 miles, if they are loose at 500 miles it means they did not put loctite on the loose ones so remove and apply loctite reinstall and check in 500 miles.
3)lube your rear anti-sway bar bushings or it will give the impression the car is bottoming out.
PM me with any questions/problems., I have no doubt I have seen it and can give you the correct answer in minuts.
