Old 03-24-2009, 08:59 AM
wideglidejoe wideglidejoe is offline
Cobra Make, Engine: FFR MK III,462 FE/TKO 600, IRS w/3.27
Default Thanks for your replies!
Rick, Clois & Barry, thanks so much for your replies!
Rick L, yeah, I knew the 4.05" was the 360/390, I was trying to keep my post as short as possible, but you and I are on the same page on a crank......I've got a 4.25 Scat that I'm trying to decide what to put it in. This block may be it. The only thing is, when I picked up the crank, I also got a set of forged 4.13" pistons (and I-beam rods), which means stock 428 bore. As far as the HV oil pump, I assume you mean a Mellings 57 (or equivalent). What about the 80 psig spring? What psig spring does it come with, and where do I get the 80? thanks for your comments!
Clois, good luck on your dyno. I need to swing by your place, I've still got some of your stuff! Thanks for the tip on Stanley. I need to look him up, and he's nice and close!
Barry R, thanks for your vote of confidence..."sounds like a nice piece". I've followed all of your stuff in the mag's, Engine Bldr's Challenge (correct title?).....very impressive!!
again, guys, thanks for the input!
Joe
Wideglidejoe
FFR#6143 Mk III: FE 462" w/four 48 IDA Weber's w/TKO 600 .82, IRS w/3.27, 17" Team III's w/245/45's & 315/35's. Gas N's.
Picked it up end of Aug '08
First start May 12, '10
First go kart May 26, '10
Tag & title 5-26-11, driving in gel coat
Painted Nov 2015
'05 Harley Wide Glide (60 hp stock, now 107 hp & 107 ft/lbs at wheel. Mid 11's in the 1/4 mi.)
'55 Bel Air hot rod project (WIP)
