Old 03-24-2009, 10:26 AM
shelby racer's Avatar
shelby racer shelby racer is offline
Cobra Make, Engine: Shelby CSX4788 with a Dawkins performance 490 ci iron genesis block hydrualic roller
Default Chris Dawkins says feel free to call him
Originally Posted by David Kirkham View Post
You mentioned the hubs were NOT pressed into the bearings. Is that true?
If so, could you please post the bearing number?
I assume the hubs use a double-row angular contact bearings in the hubs.
Also, what size bolt (shank size) holds the whole assembly together?
David
Hey David,
great to hear from you. The one Kirkham part on my Cobra is still doing great and SAI is coming up to the level of service that I have enjoyed from your company .
The hub was NOT pressed on the spindle
The bearings are held in the hub by a "C" clip on one (outer I think) side and I am not sure what is holding it in on the inner side.
The bearing number is Italy A M 01 A SKF BA213 309809 AD
Spindle nut size is 1 13/16 (45.48 mm) out side and 29.92 mm inside.
Chris Dawkins say to feel free to call him if you have questions or need more info, want to talk or have advice. You know each other so you should have his number (or I can send it to you if you can not find it). Thanks for following up.
John(;-)
Racing, bull fighting and mountain climbing are the only true sports, everything else is just a game. - Hemmingway
