Thread: Ball joint help
Old 03-24-2009, 10:40 AM
kitcarbp's Avatar
kitcarbp kitcarbp is offline
Cobra Make, Engine: West Coast, 460 Ford Racing Crate w/ TREMEC TKO 600
Default Moog ball joint
Mat, Not sure if you got your answer, but many of the aftermarket Mustang II type control arms are using the screw-in type ball joints. Yes, my understanding is Chrysler has used these from the 50's up until as recent as 1989 ! The replacement screw-in joint I found is from MOOG. Part number K-727(LOWER) K-772 (Upper) these should be easy to find.
Go to suspension.com for heavyduty PU dust boots for these as well.
"...some assembly required, ages 8 and up...... well that took longer than expected......
