Old 03-25-2009, 09:42 AM
vettestr's Avatar
vettestr vettestr is offline
Cobra Make, Engine: Cobray-C3, The 60's body lines on todays chassis technology
Dan,
You mention system had 16 pounds pressure but because the cap was rated at 16LBS and leaking, right. I think you just have a bad cap or maybe a POS between the sealing surfaces.
16 PSI is a lot of pressure and more than would allow cap removal without some effort and a big mess. If you just removed the cap on the top hose and watched it would fluid keep coming out? I think there is just a leak on your lower cap to tank.
If overflow tank cap is lower than rest of system it will seek its own level of course but what if you throw a jack under car to lift front end till the cap is the high point and watch without a cap in place or can you swap with the other cap?
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
