Old 03-25-2009, 06:23 PM
danc30's Avatar
danc30 danc30 is offline
Cobra Make, Engine: Hurricane HM1073 Keith Craft Genesis 427FE/482 CI
Pulled the plugs tonight and put the cap back on. We'll see tomorrow if it pressurizes.
Dye was used to find a leak at the waterpump bypass hose to the manifold. Successfull.
Motor has sat in a garage with temps varying from 55 to 75, no cover.
Battery disconnect has been disconnected for 2 weeks.
Heads were re-torqued at 1,000 miles and I currently have 2,100.
Cast block, aluminum heads/ manifold.
I do get a fairly big mess when I released the cap after the pressure has built up.
Cap and surface it seals against are good, 2 different stant caps everything the same.
Nothing else under pressure in the car.
If the pressure does not come back, I will do a compression test on the cylinders, but I am betting it is still there.
Can anyone help with my plug readings?
I pulled my plugs tonight to diagnose the mysterious pressurizing coolant system.
Any input on how to correct what I am seeing with the plugs I just pulled.
Pics just loaded in my gallery are a lot higher res than I can attach to the thread.
#4 is a shiny brown and was wet with fuel. # 7 doesn't look right to me, all the rest look like they are doing well.
I'd post pics here but they can only be 39kb.
Any input is greatly appreciated.
Dan
